MOSFET as ignition coil driver in electronic ignition, how to protect the MOSFET
I am building a electronic ignition for my vintage motorcycle because I had trouble finding springs for my advance unit.
It seems that nowdays they use IGBT's a lot that is some kind of darlington a mosfet and a transistor, those units are hard to get especially the ones that are dedicated for ignition systems, others lack a protective diode and are not logic level.
I want to use a 600V mosfet with a small resistance 1 or 0.5 Ohm, but how can I protect this mosfet from damaging while it is in use?
I have seen zener diodes between the Gate and Drain, do I need somtehing between the Source and Drain or not?
I tried a so called freewheel diode in parallel with the ignition coil, it could me my fault but it seems to obstruct the coil from working properly
