Looking for answers, I have a Sony Shake 6D Hifi system and has E03 power supply tag error. However for some time. Unit is working like a couple of hours but after minutes sometimes E03 triggers. I did check the voltage. And they were nominal as indicated by the service manual. I have seen bloated Capacitors on yhe amp section, but I can easily swap them out.
However chances might be , caps will bloat anytime if issue is unaddressed.
How can I measure negative voltage on analog multimeter?
I tried to measure the positive voltages, same as output from the service manual.
Since Eo3 triggers, No voltage output can be read anymore from the positive rails.
How can I make sure that the smps is producing right voltage without tripping the Protect E03 error?
I dont have a schematic for the smps, only for the Amp driver circuit as includid in the service Manual.
