Hey guys, we have an interfacing project using Visual Basic.
Basically, we should have a circuit with multiple LEDs(we're planning to use 14 pcs.), And so, by using Visual Basic,
we should be able to turn on or off each LED just by pressing a button on the VB program.
Problem is, we can't use an Arduino board, and instead we need to use a serial port as output.
Correct me if I'm wrong, I would need to purchase a USB to RS232 Cable right?
Other than that, what other components do we need to use?
Furthermore, when I have all the needed components, in what sequence should they be in(from USB port to the LED itself)?
Any help would be greatly appreciated, Thanks!
(If I'm posting in the wrong subforum, I apologize)
