Wow! I have finally made my device and it is working perfectly well. ELECTRONIC COMPONENTS REQUIRED-enamel coil of about 100turns[36s.w.g), 500pf/0.0005uf variable capacitor,germanium/semi-conductor diode, 0.01uf capacitor, 4.7kilo-ohms resistor, 1uf capacitor, 100kilo-ohms resistor, n-p-n transistor, a headphone, 6volt battery and a aerial antenna of about 50m/500cm. CONNECTION-connect the aerial antenna to 1/3 of the coil starting from the end to count. Take one end of the coiled wire and connect it to the earth such as a water pipe will increase its sensitivity, then straight to one end of the variable capacitor, then take the other end of the coiled wire and connect to the second end of the variable capacitor( creates a resonator). Connent one end of the coiled wire to the two ends of the germanium/semiconductor diode(i used germanium diode) then straight to the 0.01uf capacitor, connect the other end of the wire straight to the other end of the 0.01uf capacitor.connect one end of the wire to one end of the 4.7kilo-ohms resistor and the other end of the wire to the other end of the same resistor.connect one end of the wire(which is connecting with one end of the 4.7kilo-ohms resistor) straight to the two ends of the 1uf capacitor, the 1uf capacitor is then linked with the 100kilo-ohm resistor and the collector of the n-p-n transistor straight to one side of the headphone and straight to the +ve side of the 6volts battery. Remember we only connected one end of the 4.7kilo-ohm resistor to both ends of the 1uf capacitor, if you don't please look up at the process to recur again. Now that we have recurred, connect the other end of the 4.7kilo-ohm resistor to the emitter of the n-p-n transistor straight to the other side of the headphone and then to the -ve side of the 6volts battery.thats is!!! Please guys i need testimonies!.
Platforms
Content
