Hi Everybody!
as you can guess from the subject I have a problem with the DC Power Supply N5771A and I'm looking for some useful tips because I'm sure, I'm not the one who has faced this problem.
I have created a program which reduces the output voltage progressively (from 40 V to 2 V) but I have a problem when the device should apply the voltage: if I set a fix number (using a direct I/O object and a string “VOLTAGE 40”) the Power Supply responds applying the correct voltage but if I use a variable as an input for the direct I/O object (for example c with c varying from 40 to 2), the device doesn’t change the output voltage . I haven’t found any help in “direct I/O transaction” how to write a voltage which changes with time. Can maybe someone suggest me which programming code I should use?
I've already tried:
WRITE TEXT "VOLTAGE"+c REAL64 STD:4 EOL
WRITE TEXT "VOLT:LEV "+C+" <NRf>"
Thanks!!
ice
I've already tried:
Thanks!!
ice
