Hello,
I have been experimenting with different types of oscillators for a while and recently I've been stuck on a royer oscillator. In the simulation I can generate oscillations, but when I assemble the oscillator in real life, no signs of the desired result appear in the secondary circuit.
I attached a picture of the schematic and the .asc file, to this thread. The secondary (high voltage) circuit has been removed because when it is added to the circuit in the simulator, the circuit ceases to function. In real life the secondary coil isn't attached to anything.
The transformer I'm using has an air core, since I'm trying to produce oscillations in the radio frequency range.
I would be very grateful, if someone can point out the mistakes I'm making ang give advice on how to create the secondary circuit in LTSpiceIV without getting error messages or supressing the oscillations, by grounding the secondary coil
Thank you,
Revala
Thank you,
Revala
