Simoc
I built an ESR meter according to this link:
http://www.ludens.cl/Electron/esr/esr.html
As I completed building its electronics, it worked. Then I made a
casing for it and installed it there. When that was almost ready, I
tested it, and it still worked. But there wasn't yet a place for a
battery in the case, I made it now (had to detach the circuit board
then), and replaced the board. Then I tested it -- and it...didn't
work!
I took all the guts out from the casing, and measured _every_ component
I can with a DMM, tested the op-amp by using as comparator, and
measured _every_ connection, got 0 ohms and no shorts in wrong places.
So virtually only possibly broken component is the transformer. But I
don't think.
So what could have gone wrong? As I'm pretty unfamiliar with using an
op-amp as an oscillator, so could someone here explain how is it done
in that circuit? And how could I debug the circuit by measuring
voltages on some points on the circuit with power on, to find out where
is the problem? I just have measured that op-amp gets the necessary 5V
on Vcc.
Thanks in advance
work!
don't think.
on Vcc.
Thanks in advance
