Could someone please help with a mess I have made of a simple DC power supply.
I have a toroidal transformer with 130v 0v 130v 0V input and 18v 0V 18V 0V output. I have wired the input as 230V. The output is wired to give 18V using both windings. Each single ouput winding is rated at 4.44A and 2 should be 8.88A.
I have used a 10,000 uF cap rated at 63V. The bridge rectifier started at a 10A but I have also tried a 35A and a 50A. The cap has also bee replaced by a 820 uF 200V.
None of this is helping. The no load output from the AC is 19V at all times which is correct because our mains is 245V and not 230V. This should give a DC output of 27V under load. (19V x 1.4141).
A load of 5A ( a car head lamp (60W + 65W) wired to use both filaments is series) drops the DC output to 16V but the AC transformer output remains at 19V. The input to the transformer stays at 245V under load.
I thought that a load of 5A would not have dropped the ouput voltage down to 16V.
I have tried 2 different meters.
I have made 2 other DC supplies with no problems. I am making a simple error but I have no idea what it is.
![Dscf1177.jpg Dscf1177.jpg](https://makerv2.webteractive.co/forums/data/attachments/34/34950-5dde0f3ed1474d18ae16527ba4793ec2.jpg)
