Christopher Tidy
Hi all,
I recently bought a 2.1 mm DC line socket from Maplin (part no. JK11M)
so I could power a project using a plug-in power adaptor (wall wart).
Soldering a lead to the outer coaxial contact was no problem, but when
I tried to solder a lead to the inner contact, the plastic insulation
melted!
I'm not a novice to soldering and I wasn't using an inappropriately
large iron. The iron I was using is an Antex rated at 18 watts,
although it isn't a regulated iron. I didn't touch the plastic
insulation with the iron. The joint clearly didn't get hot enough to
melt the solder, so I reckon the plastic must have melted at less than
180 deg. C.
The Maplin socket design is bad in two ways. Firstly the insulator is
made from a thermoplastic, and secondly the solder bucket for the inner
contact is right next to the plastic insulator.
So I have a few questions. Are all 2.1 mm line sockets like this or are
there better designs out there? If there are better ones available,
where can I get one from? And how are you supposed to solder these
sockets with thermoplastic insulators?
Suggestions would be appreciated.
Best wishes,
Chris Tidy
melted!
180 deg. C.
Best wishes,
Chris Tidy
