Robin
I was wondering if somebody could tell me how to fix a problem I'm
having with my Sansui AU-101 solid state amplifier.
Since I got the device, I'm having this problem with my right channel.
The left channel works perfectly, but the right one doesn't produce any
sound. When I turn up the volume to the maximum, I can hear some very
soft noise on the right channel.
I think the problem is located in one of the 4 transistors located at
the rear end of the amplifier. When i was trying to obtain the voltage
going through the transistors, i accidentally hit the base of one of
them, and for a few minutes the amp worked perfectly again. :S
As far as i see, the base of all 4 transistors are not connected to the
printboard. It says 'Hitachi 1060D'. Unfortunately i didn't find any
specifications of the (FET?) transistor on the net, nor do I have a
technical scheme of the amplifier.
I hope somebody will be able to tell me how I can find a nice
equivalent for this transistor.
Thanks in advance!
Robin
Thanks in advance!
Robin
