Hello, i've the multimeter DT9205A and I measured the voltage of a new AA battery it says 1.57 V, then I connected the battery in series with a 990 ohm resistor so the current should be 1.57/990 = 1.58 mA but measuring the current with the multimeter it says 1.40 mA that is a bad measure, but why it happen?
I read that in my calculations i should add to the 100 ohm internal resistance of the multimeter so 1.57/1090 = 1.44 mA or to subtract about 0.2 V because the multimeter internal voltage drop when measure current so 1.37/990 = 1.38 mA but what is the real problem?
Is the voltage measure 1.57 V correct or this multimeter isn't even reliable for tension measures?
Thank you!
Thank you!
