Starflex said:
Hi Ken,
Sorry, I'm italian and I have some difficulties to explain correctly the
problem (..of course, not because "I'm Italian"...but because I don't speak
english very well..!
First of all, if you want, you can download the service manual (PDF) from
this site:
www.scooterclub-nolimits.it/E500.pdf
Now I try to describe the problem.
I gave this monitor for free, from a friend, that don' t use it because it
had some problems.
The monitor was very "out of convergence", and I solved the problem only
moving the fold poles on the tube, and finally using the regulation of the
OSD.
But the principal problem, now, is another: the monitor appear too bright.
If I put the brightness at the lower valour, and the contrast at the higher
one, the monitor is too bright.
The red appear nearly orange, the black appear too bright...like a black
t-shirt that you have washed many and many times (sorry for the stupid
example).
This is the problem.
Moreover, at this time, I don't have an oscilloscope (sigh!) to check signal
form...
First off your English is fine. You might use different descriptive
words than I would use, but I think I understand what your problem is.
The monitor you have is NOT the same one I have. Mine is a 19" Dell
Trinitron made by Sony and the problem sure sounds the same. Below are
a few links that might not be exactly about your monitor, but you should
get the idea of what the problem is if your monitor is of the same type.
The monitor has a port that can be used to adjust the G2 voltage, but
it requires software and an adapter be made. The details on how to do
this are probably mentioned in the links below. The only problem is it
is a lot of work for only one monitor. If you had many, it might be the
way to go.
There is however a modification that can be made to bring the monitor
into a usable setting. On my 19" monitor my notes say to replace R459
(10Meg) with a 4.6-6.8Meg one. (If the present value of that resistor
is not accurate, disregard the value and resistor number I suggested.)
There then is another (different) resistor that you must modify rather
than the one I suggested. The links I suggested might give you the
correct one? The resistor is of course in the rear of the monitor on a
vertical mounted PWB above the flyback area. It is not on the main
horizontal PWB that the flyback transformer is mounted.
The key is you are modifying the bias for the transistor controlling
the G2 voltage to the CRT. Once you find the current resistor, jumper
in some different values until you get the correct brightness. Do this
check with your brightness and contrast at the midrange setting.
http://www.short-media.com/forum/showthread.php?t=19549&page=14
http://www.geocities.com/gregua/windas/
http://www.google.com/search?hl=en&q=Sony+G500&btnG=Google+Search
If you write back I will try to answer any questions you might have or
suggest where you might find more answers. A search on Google for "G2
too high, Sony, Dell, Trinitron, etc." might also be productive.
