Dear All,
I am trying to figure out the problem that I am facing while programming 24C1024.
I am doing a byte write and byte read operation, however everytime I am exceeding over 255 my data is rolled over from intial (zeroth location).
As per datasheet, the roll over should happen only with page write operation.
please help!
the code is as follows:
WRITE OPERATION
void EEPROM24C_Write(unsigned char data,unsigned int address) //(unsigned char data,unsigned char address)
I2C0_Init();
I2C0_Start();
if ( 0 != I2C0_Write(0xA0,0x18))
I2C0_Stop();
I2C0_Start();
I2C0_Write(0xA0,0x18);
I2C0_Write((address>>8),0x28); //(0,0x28)
I2C0_Write(address,0x28); //(address,0x28)
I2C0_Write(data,0x28);
I2C0_Stop();
READ OPERATION
void EEPROM24C_Read(unsigned int address, unsigned char no_of_bytes, unsigned char *read_buff_ptr)
unsigned int last_addr = address + no_of_bytes;
unsigned char rem = 0;
// I2C0_Init();
I2C0_Start();
I2C0_Stop();
I2C0_Start();
I2C0_Write(address>>8,0x28);
I2C0_Stop();
I2C0_Start();
I2C0_Write(0xA1,0x40);
if (address > 255)
rem = (last_addr + 1) % 256;
if (rem != no_of_bytes)
no_of_bytes -= rem;
else
rem = 0 ;
for ( ; no_of_bytes > 0; no_of_bytes--)
if (1 == no_of_bytes)
*read_buff_ptr = I2C0_Read_Single_Byte();
else
*read_buff_ptr++ = I2C0_Read();
I2C0_Stop();
if (rem)
I2C0_Start();
I2C0_Stop();
I2C0_Start();
I2C0_Stop();
I2C0_Start();
for ( ; rem > 0; rem--)
if (1 == rem)
else
I2C0_Stop();
/**************Function Prototypes************/
void I2C0_Init(void);
void I2C0_Start(void);
void I2C0_Stop(void);
unsigned char I2C0_Write(unsigned char data, unsigned char status);
unsigned char I2C0_Read(void);
unsigned char I2C0_Read_Single_Byte(void);
PINSEL0 |= 0x50; /*Initialize Pin Connect Block P0.2 as SCL0 P0.3 as SDA0*/
I2C0CONCLR = 0x2C; /*Clear AA, I2C Interrupt Flag, Start Bit*/
I2C0CONSET = 0x44; /*Enable I2C0*/
PCLK = 15MHz
I2C Frequency = 100KHz
Formula:
I2C Frequency = PCLK/((I2CSCLH + I2CSCLL)
(I2CSCLH + I2CSCLL) = 15000/100 = 150
I2C0SCLH = 75;
I2C0SCLL = 75;
/*Bit Rate 100Khz*/
I2C0CONSET |= 0x20; /*Set the Start Bit*/
while(I2C0STAT!=0x08); /*Wait for the Status Set*/
I2C0CONSET |= 0x14; /*Stop I2C*/
I2C0CONCLR = 0x08;
unsigned char I2C0_Write(unsigned char data,unsigned char status)
unsigned int i = 0xFFFF;
unsigned char err_status = 0;
I2C0DAT = data;
I2C0CONSET = 0X04;
I2C0CONCLR = 0X28;
while((I2C0STAT!=status) && (0 != i)) /* Wait for Status Set */
i--;
if (0 == i)
err_status = 1;
return err_status;
I2C0CONSET = 0X04;
I2C0CONCLR = 0X2C;
while (I2C0STAT!=0x00000058); /* Wait for Status Set - 0x58 */
return(I2C0DAT);
I2C0CONSET = 0X04;
I2C0CONCLR = 0X28;
while (I2C0STAT!=0x00000050); /* Wait for Status Set - 0x50 */
return(I2C0DAT);
Please Help!
thanks,
Sid
please help!
WRITE OPERATION
I2C0_Init();
I2C0_Start();
I2C0_Stop();
I2C0_Start();
I2C0_Stop();
READ OPERATION
// I2C0_Init();
I2C0_Start();
I2C0_Stop();
I2C0_Start();
I2C0_Stop();
I2C0_Start();
if (address > 255)
no_of_bytes -= rem;
else
rem = 0 ;
else
I2C0_Stop();
if (rem)
I2C0_Start();
I2C0_Stop();
I2C0_Start();
I2C0_Stop();
I2C0_Start();
if (1 == rem)
else
I2C0_Stop();
PCLK = 15MHz
Formula:
I2C0SCLH = 75;
I2C0SCLL = 75;
/*Bit Rate 100Khz*/
I2C0CONCLR = 0x08;
I2C0DAT = data;
I2C0CONSET = 0X04;
I2C0CONCLR = 0X28;
i--;
if (0 == i)
err_status = 1;
return err_status;
I2C0CONSET = 0X04;
I2C0CONCLR = 0X2C;
return(I2C0DAT);
I2C0CONSET = 0X04;
I2C0CONCLR = 0X28;
return(I2C0DAT);
Please Help!
thanks,
Sid
