Problem Uploading the sketch to arduino uno.
I wrote a sketch on arduino IDE and tried to upload to the board. Had following error while uploading
Sketch uses 7958 bytes (24%) of program storage space. Maximum is 32256 bytes.
Global variables use 483 bytes (23%) of dynamic memory, leaving 1565 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM11 -b115200 -D -Uflash:w:C:\Users\SBI\AppData\Local\Temp\arduino_build_850591/lll.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM11
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x8f
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Tried google and the steps at different forums, nothing worked for me, also there is no clear cut solution, there is a mix of hit and try, If anyone could lead me in the right direction as to what is the problem occuring?
Tried burning the bootloader this is the log. unsuccessful.
Warning: Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
Archiving built core (caching) in: C:\Users\SBI\AppData\Local\Temp\arduino_cache_985796\core\core_breadboard_avr_atmega328bb_0c812875ac70eb4a9b385d8fb077f54c.a
Sketch uses 4418 bytes (14%) of program storage space. Maximum is 30720 bytes.
Global variables use 483 bytes of dynamic memory.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM11 -b57600 -D -Uflash:w:C:\Users\SBI\AppData\Local\Temp\arduino_build_101228/ArduinoISP.ino.hex:i
Using Port : COM11
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xbe
still not working. please help
