I'm using an ATX power supply to power some 40w leds. I was using several older power supplies, and they work great, but i wanted to buy a new one and clean up the design- it was pretty funny looking with wires sticking out everywhere etc.
Anyway, it seems to work just fine- i hook everything up, turn the power supply on and the light comes and stays on. But after i turn it off, i can't turn it back on again- the power supply does nothing- no fan, no sounds,and luckily, no smoke.
I've been reading various forums for a couple of days now and it seems that i'm doing everything right, but still unsure- the power supply was working normally before, and i don't see what could be causing the problem.
I cut all of the connectors off that go outside the case and separated everything into colors. I only need 12v, so i isolated black and yellow.
On the old supply, i only needed a black and green soldered together, but i had been reading that i also need to connect a brown to an orange, which i tried but no luck. I also tried putting various resistors between red/black and orange/black, i've read that some power supplies require a dummy load. It doesn't *seem* like it would be a problem though since it turns on and works just fine the first time.
Does anyone have any ideas? This is a new power supply, and i tested it before cutting wires, was functioning fine (before i got my paws on it anyway)
