I am using a OP07 as an inverting amplifier.
With Rin=1k and Rgain=100k the gain is about 100.
The output is directly connected to a voltmeter (ie, I didn't put a
Rload in the circuit).
I use 1uF and 0.01uF decoupling capacitors on the +/-15V supply.
I use a 20k pot (as specified for the OP07) to trim the input offset
voltage.
The circuit is working well on the test breadboard.
BUT after I soldered all the components on a prototyping PCB the offset
voltage increase by a factor x90 (about 180mV with the inputs shorted,
compared to 2mV on the test board ). This offset is so high that I
can't trim it!
I tried the change the capacitors and the op-amp... but did't solve the
problem.
I noticed that without the decoupling capacitors the offset is even
higher (about 5V).
I really don't see what produces this abnormal offset (the strangest
being that the circuit works very well on the breadboard).
Does anyone has an idea?
Nicolas
voltage.
can't trim it!
should give max 3mV after the x100 gain, not 180mV.From the datasheet, the OP07 has an input offset of about 30uV, which
problem.
higher (about 5V).
Nicolas
