After scouring the manuals and newsgroups for possible solutions with
no luck, I thought I would post here to see if anyone might have an
idea as to what Im doing wrong.
Im trying to enroll a RF5501-433NA keypad with my DSC 632 (PC1555MX
CP-01) system. The Keypad manual says that it enrolls as two
modules... "1 = keypad section ...17 = receiver section". I entered
programming [*][8][xxxx], entered keypad programming[000], selected
Partition and Slot assignment [0], and specified [01] as the partition
and slot values. I then exited programming, went back into program
mode [*][8][xxxx] and did the supervisory reset with [902]. I waited
several minutes for the controller to scan the bus...and then displayed
all modules with [903]. The only module found/displayed was 1....the
keypad. According to the install instructions...17 (the receiver)
should have also been found. The instructions say that if both modules
do not show on the keypad, then 1) keypad may not be properly connected
on the bus, 2) problem may be with keybus wiring run or 3) the keypad
does not have enough power. Ive checked all my connections and I'm
pretty confident that it is connected properly. My run is
short...like..less than 50'...and...I dont know why there would be a
problem with power.
Does anyone have any thoughts or suggestions that might help me get the
receiver enrolled.
Thanks -- Jeff Gaiche
problem with power.
receiver enrolled.
