Hi.
I'm trying to run a µC (PIC18f26K22) with prioritary interrupts. It generally works fine but it's like when an high priority interrupt stops a low priority interrupt, the µC never returns to the low priority one.
My program is a little heavy (65ko), so I won't post it here, but is there anything I didn't understand well on using prioritary interrupts ?
I see in documentation :
Do I have to save anything when entering in a low interrupt routine or is XC8 compiler handle the problem itself ?
Thanks for your answers.
5.2.2 : Fast Register Stack said:If both low and high priority interrupts are enabled, the
stack registers cannot be used reliably to return from
low priority interrupts. If a high priority interrupt occurs
while servicing a low priority interrupt, the stack register
values stored by the low priority interrupt will be
overwritten. In these cases, users must save the key
registers by software during a low priority interrupt.
