preamp design for mic
I'd use AC coupling.
If your 1.1V reference on the op-amp is out by even 30mV, the output will get pinned to one rail or the other.
The chance that *something* isn't going to vary by a few mV is pretty slim. Your 1.1v reference is tied directly to your power supply and will vary with voltage, but worse, any noise on the supply rail will be amplified by your amplifier. (it would get amplified about 30 times)
ac coupling
I have a problem with the ac coupling... the value of capacitances are very high. plus when I ac couple the output terminal I get a waveform with 0v ref. Which gives me both negative and positive peaks. Could this damage my mic....
What do you mean "the value of the capacitances are very high"?
No, this will not damage your microphone, which is the *source* of the signal.
You will probably have other problems (because you're using a single ended power supply) but this won't be one of them.
Actually, the circuit I pointed you to is already designed for a single ended power supply.
non inverting amplifier with ac coupling
I have remodelled my design according to what you have told me... but the problem is now my opamp output is at a dc offset of 1.73V even though I am trying to keep it at a dc offset of 1.5 volts..... can anyone tell me how I can maintain the dc offset of my circuit....
Similar threads
