I
Ignoramus7428
I am trying to find the easiest way of making a very low power
transformer. Its job will be to convert 240V to some voltage such as
100V (exact value does not matter). This voltage will have an only use
for voltage sensing, and several milliamps should be quite enough.
So... With that in mind... What is the easiest design for a
transformer. What is important is that
1) it does not get too hot and
2) it could produce a few milliamps.
How about:
1) using a steel rod such as a very thick nail, and two windings
2) using a ferrite toroid (I read unfavorable comments about doing that at
60 Hz).
3) using a few washers stacked together for a steel toroid
4) using a little toroidal cutout from a steel pipe
Anything else that is quick and dirty?
i
How about:
60 Hz).
i
