Christopher Grenness
I just received my new PowerMax+, and started fiddling with the menus
not paying too much attention to the manual (the information on the
display looked informative enough to me).
Along the way I decided to change the Master Installer Code, and later,
when giving out user codes to myself and my wife, I made the (fatal?)
decision that my own user code should be the same as (my) Master
Installer Code. No error messages, so I thought everything went well.
Later, however, I experienced several problems hooking up the GSM module
and defining it to be the only telephone line. The panel kept nagging
that there was something wrong with the telephone line, even though I
also received SMS'es which to me showed that everything worked ok.
Anyhow, I decided I wanted to reset the whole system and start over with
the installation manual at hand, so I tried to enter the menu choice of
"resetting to factory default". But of course, entering my PIN only gave
me access to the ordinary menu. None of the default codes (9999, 8888,
1111) worked.
I unplugged the power supply and the backup battery and left the panel
without power during the night, but as suspected it wasn't enough to
make it forget my mistake...
Are there anything else I can do in order to undo my coding mistake?
Regards,
Christopher
1111) worked.
Regards,
Christopher
