Hello forum. Noob here, pleased to meet you.![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a battery operated clock that I want to adapt for AC, and illuminate it with two constant running LEDs.
The clock was designed for two AA batteries, so I figured I'd get a 3 volt wall adapter, cut the end off, and wire it to the batt terms. They're on ebay as cheap as a dollar. What's involved with wiring in two high intensity LEDs? I've found 3 volt LEDs, but it seems they're sensitive to mA. most run at 250, and most wall adapters put out 400-1000mA.(the switchable multi-volt adapters put out 1000). I read the MODS sticky on LEDs, but it's way over my head. I do understand that they need to be either in series with one resistor, or parallel with 2 resistors. Which is better for my application?
What LEDs should I use, and what resistors? And will the mA rating on the adaptor effect the operation of the clock itself?
The LEDs will be on 24/7, so should I look for a higher capacity LED, like 4 volt? or underpower the amperage?
Any help would be greatly appreciated.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
