I've got a double din car radio I'd like to be able to use/test in my house so I'm trying to figure out the best way to power it. Someone on another forum suggested a desktop PSU, but for the technical electrical questions I decided to come to a forum dedicated to this kind of thing...
The DD radio is powered off of a 12Vdc source (according to the manual). The manual doesn't mention amps at all except for the fact that in the back of the radio these a 10A ATM fuse. So I'm assuming the fuse is there to protect the entirety of radio it self.
My PSU supposedly has some cables that do a max output of +12V/19A. (I included a pic of the PSU). That should be safe to run off of, correct? I realize the amps are to high but the fuse should protect the radio.
My next question, is figuring out which wires are the +12V/19A ones...According to wikipedia, http://en.wikipedia.org/wiki/Power_supply_unit_(computer), the +12 are either of the yellow ones, and the ground are black. Those should be the only 2 wires I need.
Is all that correct? I'm just looking for some verification before I fry my new $500 radio.
Edit: and I guess a follow up to my question is, if I keep the PSU plugged into the motherboard, will I get the same +12/19A from the molex connectors? It's easy to test the 12V+, but I'm confused on how to test the amps, without actually plugging the radio in first. On the one hand I would like to make sure it's not way to much current (which the 10A ATM fuse should protect), but on the other hand, I don't want to turn the radio on without enough current and 'starve' the radio.
![img20120708122943.jpg](/forums/proxy.php?image=http%3A%2F%2Fimg406.imageshack.us%2Fimg406%2F8697%2Fimg20120708122943.jpg&hash=ab1e4399906c4cfc39d4be03f1afa993)
