L
ll
I am in the process of replacing a power transformer in a musical
instrument amplifier (solid state). As the existing transformer
doesn't currently pass the continuity test across the primary, and the
coil wire seems to be broken somewhere in the coil, I am thinking of
just replacing it. How can I find the power rating of the existing
one? I know that the amp is rated at 30 watts.
If watts=amps x volts, then 30watts = 115v x 3.83amps. Would I need a
transformer that was less than or equal to the 3.83amps with the same
voltage?
Thanks,
Louis
voltage?
Thanks,
Louis
