power supply to drive a DC motor
What type of AC>DC power supply should be used to drive a DC motor? I have seen switched and linear power supplies. Some are regulated and others non-regulated. I want to use this instead of the large car size battery the motor currently uses.
Any supply as long as the voltage matches that of the motor and the current is high enough for the motor.
davenn
hi junksasa
frank's point was kinda obvious you already knew that ;)
Harald's comment was totally valid
since you havent told us anything about the motor ... its voltage or current ratings
Harald's advice was the best that could be given ;)
Dave
hi junksasa
Dave
If thats true then why are there PS that are switched and linear, regulated and non-regulated? What are the applications for these different types of PS? My motor is 24VDC, 5A nominal, 10A loaded.
switched mode vs. linear:
SMPS have high efficiency (low loss), but are comparatively noisy.
Linear regulators have low efficiency (high loss), but cqn be very silent (low noise).
Regulated vs. unregulated:
What's the question? It is obvious, isn't it?
If you need a precise voltage, you regulate. If your requirements with respect to voltage regulatioon are low, you can use an unregulated supply. For a motor you don't need a regulated supply - unless it is explicitely stated by the manufacturer (e.e. if the motor is electronically commutated, also called brushless. But that's another story).
Read this overview.
