Power Supply Switching & charging battery
Y2R3vBV
So my aim is create/find a circuit that will switch between 2 power supplies as follows:
1- When generator is [OFF] - The battery will power the load
2- When generator is [ON] - The generator will power the load and supply power to the charger in order to charge the battery.
Note: Switching between both supplies must be done simultaneously to ensure no interruption of power.
Thank you!
Seamless switching can be done with two diodes:
Note that the generator needs to supply a slightly higher voltage than the battery. Otherwise the battery would power the load all the time.
Good idea, now how would I go about supplying power to the charger this way? I believe supplying the charger before the diode on the gen side would work, correct?
