This light stopped working when I switched it on.
Here is the little power supply:
On checking the 2 big 13005 transistors are shorted between all legs. Bit surprised by this as they are hefty jobs and show no signs of damage.
Also the diode D5 is open. It's marked DB3 and C53 as far as I can tell. Could it be this guy:?
https://datasheet4u.com/datasheet-pdf/STMicroelectronics/DB3/pdf.php?id=193115
240V in and AC 12V/40kHz out. Input current 185mA Power 50W max
The 4 Bridge rectifier diodes are good
What else needs to be checked.I don't know what the heatshrinked device bottom right is, so don't know how to check it. It measures 1.5MΩ
What else needs to be checked or can I just replace the transistors and the diode?
Many thanks for the help
