Hi all,
I have a CADDX RANGER 7600 alarm at home for more than 10 years without problems, but now the red led "Power" is blinking instead of fixed. According to documentation, it is low battery indication, so I've replaced but still the same. Then I measured the voltage that alarm is providing to the battery and I found that it is providing only 13 volts to the battery (measured without battery connected) instead typical 13.8 volts, and I guess that it can be the cause of the problem. There is a variable resistor named "P1" which could set the output power to battery, but I am not sure. Could anyone help?.
Thank you a lot.
http://i.imgur.com/0RswS.jpg
http://i.imgur.com/MdvYK.jpg
Thank you a lot.
