Hi all,
What is the efficency of a cold cathod tubular bulb ? Is a 8W CCFL worth
the light output of a 80W plain old incandescent bulb ?
First of all, no fluorescent lamp I know of is 10 times as
efficient as an ordinary 80 -watt incandescent lamp would be
if there were such a lamp. (I am using 75-watt and 100-watt
incandescent lamps as my benchmark.) Very good fluorescent
lamps are about 6 times as efficient as 75-watt and 100-watt
120-volt incandescent lamps, and perhaps 7.5 times as
efficient as 100-watt 230-volt incandescent lamps,
Second, cold cathode fluorescent lamps are significantly
less efficient than thermionic (hot) cathode fluorescent
lamps UNLESS they have a high length-to-diameter ratio. If
that is the case, they will have about the same efficacy as
a hot cathode fluorescent lamp. The reason for the low
efficacy of CCFLs with low length-to-diameter ratios is the
very high voltage drop between the discharge and the cold
electrode, compared to the much lower voltage drop between
the discharge and a thermionic cathode. This high voltage
drop can only be offset with a very high positive column
voltage. High positive column voltage drops are present in
lamps that have high length-to-diameter ratios.
Vic Roberts
http://www.RobertsResearchInc.com
To reply via e-mail:
replace xxx with vdr in the Reply to: address
or use e-mail address listed at the Web site.
This information is provided for educational purposes only.
It may not be used in any publication or posted on any Web
site without written permission.
