V
Valentin Tihomirov
Background:
Hello, I've developed two devices. They have absolutely different purposes
and voltage regulation systems. The first is based on linear regulators the
second is based on switching regulators. Both systems are based on the same
MCUs (TUSB3210). They have an external crystal and internal oscillator. The
oscillator starts oscillating very stably when I power the device from:
- DC supply (6v .. 40v)
- AC/DC adapter with stabilized output (5v)
- USB hub (5v)
The Problem:
However, there are two types of AC/DC adapters that cause problems with
start up. The oscillator does not start (it seems that it starts for several
milliseconds and becomes dim), positive polarity signal is coming from rs232
driver causing errors to connected systems. This problem occurs only when I
connect output of the powered adapter into power socket of my device. If I
change the order plugging the output of adapter into my device and only then
insert the adapter into outlet the system starts OK!
I have done some homework and additionally figured out that the DC supplies,
which do not cause problems at start up, charge the power line of my device
smoothly. That is, according to theory of phisics, the capacitors (2x300uF,
filtering input and output of switching power regulator) should be charged
exponentially. This (smooth characteristic) is what I see using correct
adapters. The picture is quite different using the problematic types of
AC/DC adapters. I clearly see a segment of linear growth of voltage of power
line during power-on.
I have solved the problem by adding a coil to the input of power regulator.
This has improved the characteristic of power line voltage raise. For the
time being the characteristic is purely exponential. Have anybody faced the
same problem and what could be the cause of such a strange behavior?
- USB hub (5v)
The Problem:
