Richard Bair
I have some questions regarding how to test/determine the minimum power line
quality required for a design that has two inductive loads.
BACKGROUND:
- 115V 20A rated
- Device will introduce two inductive load starts at 3-10min apart. Thus,
when the second inductive load starts there is already ~7-8A steady state on
the line.
- Each device can have a peak inrush of up to 80A (motor starting)
QUESTIONS:
- How can I verify the worst case power line conditions required for this
product? What I mean is...I believe NEC will state there can't be more than
a 3% voltage drop. Is that only for steady state?
- What about the peaks a line can provide? I suspect many lines at typical
distances/impedances will start to current limit and voltage will sag with
80A of inrush current.
Thanks!
BACKGROUND:
- 115V 20A rated
the line.
QUESTIONS:
Thanks!
