Hi folks - new to EP here and a novice in electronics.
I need to drain the electrolytic caps in the power filter section of an old tube amp and don't have the recommended 10W 25k Ohm resistor suggested for use to avoid a spark.
My question is about ganging together 4 100k Ohm 2W resistors. The aggregated resistance should be the target 25k Ohms, but I'm not sure if the overall power handling will be 8W (i.e. 4 x 2W) ? I would imagine it would have to, with the current being split four ways, but wanted to make sure before I go ahead.
Also, it's typical to use a cement resistor for this application, and the 2W resistors I'm considering are metal film. Would there be any concern in not using a cement resistor here - i.e. all other things being equal, how does a resistor made of cement differ functionally from metal film?
Thanks!
Thanks!
