So to recap.
Watts measures a rate of flow of energy. A Watt is a Joule per second.
In many electrical things watt-hour is a more convenient measure, as above, as a Joule is not a lot of energy in the power world.. A Watthour is a Joule per second for an hour, or 3600 Joules.
Something heating at 10 watts means it absorbs 10 Joules per second.
So for the example of an electric jug heating water, the power (watts) tells you, for any particular fixed amount of water, how quickly the water will heat.
For a partcular amount of water, with all the energy going into heating the water, the total energy absorbed (watts times time) will tell you how hot that amount of water gets in the time you heated it.
So, more Watts, means doing things faster.
Generally, of course, you pay someone for the total energy used, Watthours, not Watts.As suggested by what Harald Kapp said, the higher the power, the faster it counts Watthours, the faster the bill increases.
