Hi, I have a newbie question, hopefully someone is willing to help me out.
I need to replace the power adapter for an Alesis Q49 keyboard. It requires 9V DC 500mA, Pin Positive, 5.5mm outer diameter.
Is the one below correct? I'm not sure because it says "charger", and I've heard adapters for chargers can actually be a higher voltage than listed. Also it's listed as "AC", but then in the description it says "DC". I don't know how to make sense of that.
Thanks -
http://www.ebay.com/itm/9V-200mA-AC...=Laptop_Adapters_Chargers&hash=item3f288bbd59
9V 200mA AC Adapter 300mA Power Supply Cord 5.5mm 2.5mm Tip 2.1mm 500mA Charger
Compatible Replacement New DC Adapter Charger Power Supply PSU
Features & Specifications:
100% Generic New and High Quality Compatible Replacement
Input Voltage : AC 100-240V (Worldwide AC Input)
Input Frequency : 50-60Hz
Output Voltage :9V 1A Max Center +
Connecter Size : 5.5mmx 2.5mm/2.1mm
Note: Please make sure the DC output and tip size of ac adapter are accordant before you bid.
Industry Quality : Over Voltage Protection, Over Heat Protection, CE
Package include:
1 x AC/DC Adapter Home Wall Charger Power
Thanks -
Package include:
