Portable vacuum cleaner repair
Hello guys,
I am trying to repair my 9v portable vacuum cleaner. The appliance works but there was a strange smell so I opened it up and I noticed that a small component is burned, I am a beginner in electronics so I don't know what it is, I have attached a photo so maybe some of you can tell me what it is.
Thanks a lot
davenn
looks like a large ( 1 to 2 Watt) resistor
if you have a soldering iron unsolder one end and if you have a multimeter
try measuring the value of the resistor
Dave
Dave
Report Post Today, 10:31 PM #3
I did that and on the 20k setting the multimeter shows 1..which I think means 1 k ohm... But is the reading correct since the resistor is damaged ? shoud I buy a 1 k ohm resistor?
Thanks for the help
davenn
OK
generally resistors will usually go either really high resistance or go open circuit ( ie. pop like a fuse)
the fact that you are getting a reasonable reading, I would cautiously say that it probably is a 1k resistor, get one in the 2W - 5W range and see how you go
report back :)
Dave
OK
report back :)
Dave
Great, Thanks a lot :)
