K
krw
To-Email- said:Like Ohio ?![]()
WAIT A MINUTE! The useless states are on either end. You want to
be left alone with the weenies?
You still want to keep the house dehumidified during the day.
I recently interviewed with a company that makes smart power meters.
They can control loads, so the power company can level loads without
blacking out everything. For instance, I doesn't matter much if a
water heater is turned off for a few hours, or the water heaters
across town are cycled. Much better to turn them off for some hours
during the day than have large peaks. The meters network with their
neighbors so metering and control can be done across wide areas.
Slick stuff.
Jim Thompson said:On Fri, 23 May 2008 09:25:52 -0700, "Bob Eld"
[snip]
The governor of Wyoming wants to make synthetic gasoline out of
Wyoming coal. That actually makes more sense because it powers
existing vehicles. With the Hybrids the total fleet would have to
change.
But, coal in NOT the answer. The better answer is biofuels. They
must be fully developed an implemented.
Biofuels? Is that what you get when you convert leftist weenie bull
shit into methane ?
...Jim Thompson
No, actually it's collecting and utilizing the hot air, smoke and
intestinal gas from CONservative politicians and blow hard talk show
host and other repug nitwits out there. This smoke and gas is used to
raise steam in giant boilers to operate a closed rankine cycle power
plant. There is enough blow off from these jackasses to generate about
8 GWatts of power.
As with most thermodynamic cycles, republicans and CONservatives,
about 60% goes right up the chimney doing NO USEFUL work. Carnot
didn't realize he had to deal with republicans!
Well, he's not a warmingist that I know of, but he is fairly insufferable
when he spouts his statist neocon bushist crap.
Actually, when you take brain-lock into account, he's almost
indistinguishable from Bill Sloman. >:->
Political zealots.
Yeah, but nobody listens. ;-)
1. Zero emissions, except for waste heat.
2. 20 years between refuelings.
3. They can be designed to actually produce new fuel, making it
essentially free.
4. Japan and France, and probably some other countries, get a
very large proportion of their power by nuclear plants - obviously,
somebody's figured out a way to do it safely, and profitably.
5. Reactor waste, you say? Just find out where the gov't is putting
theirs, and put the civilian waste in the same place.
Pretty much, yeah. ;-)
No western power reactor has ever created any 'fallout' worth mentioning.
TMI was simply turned into a scare story by the media for example.
in messageOn Fri, 23 May 2008 09:25:52 -0700, "Bob Eld"
[snip]
change.
shit into methane ?![]()
...Jim Thompson
8 GWatts of power.
Yet it's guys like AlGore that use energy FAR above the ordinary household
in energy,while promoting "green" for everyone else.Or like liberal Ted
Kennedy who blocked the windfarm slated for far off his Hyannisport
compound.
Also the jet-set Hollywood liberals that fly on private planes instead of
more-efficient commercial passenger jets.
Leftist weenies are far more "do as I say and not as I do" than
convervatives.
Jim Thompson said:[snip]
The governor of Wyoming wants to make synthetic gasoline out of Wyoming
coal. That actually makes more sense because it powers existing vehicles.
With the Hybrids the total fleet would have to change.
But, coal in NOT the answer. The better answer is biofuels. They must be
...Jim ThompsonNo, actually it's collecting and utilizing the hot air, smoke and intestinal
gas from CONservative politicians and blow hard talk show host and other
repug nitwits out there. This smoke and gas is used to raise steam in giant
boilers to operate a closed rankine cycle power plant. There is enough blow
off from these jackasses to generate about 8 GWatts of power.As with most thermodynamic cycles, republicans and CONservatives, about 60%
goes right up the chimney doing NO USEFUL work. Carnot didn't realize he had
At least we are self-sufficient ;-)
Leftist weenies can't manage without _taking_ from more productive
individuals... Marx/Engels at its finest :-(
Richard The Dreaded Libertarian said:3. They can be designed to actually produce new fuel, making it
essentially free.
You've forgotten about Windscale then? As usual, the U.K. screwed up
first.
Jim Yanik said:Yet it's guys like AlGore that use energy FAR above the ordinary household
Slick stuff.
Michael A. Terrell said:Then you've never lived in FLorida.
rickman said:I heard a bit of a politician on the radio today. He was governor of
one of the western states. He said some things that I didn't hear any
supporting evidence for. I wonder if there are facts to support these
ideas.
He seemed to think that driving hybrids is the answer to the oil
problem. He describes this scenario. Everyone drives a hybrid which
can be plugged into the power grid and charged at night when the power
grid is way below peak usage. Then they can be driven up to 40 miles
the next day without using any fuel.
He would also set the power rates at lower amounts at off peak times
and higher during the daily peaks. You would be able to sell power to
the grid at the same price that it would cost you to buy it. So if
you weren't driving that day, you could sell power back from your
hybrid to the power company and make a profit!
He claimed that this would eliminate our need for foreign oil.
I don't get it. Sure hybrids can save fuel. If you otherwise drive a
vehicle that gets 20 MPG and you switch to a hybrid that gets 40 MPG,
you save half the fuel you otherwise would use. But a 50% savings on
auto use of petroleum is not a 50% savings in imported oil. There are
many, many other uses of oil. The fuel saved by plugging into the
power grid may not be a savings at all. Where does this power come
from? A lot of power plants burn petroleum. Otherwise they burn coal
which is very dirty or use nuclear energy which is a whole 'nother can
of worms.
I don't remember his name. Anyone here know who this is? Do his
numbers add up? Has he given any real numbers to support his claim or
is this one of those half baked ideas that sounds good in a sound
bite, like having a gas tax "holiday"?
A large part of "the oil problem" is the falling dollar and the
resulting market instability.
It'll all be fixed when crude is priced in Euros. But then central banks
won't need dollar reserves. The exchange rates will collapse and you and
I won't be able to raise the money to buy new tires for the old pickup
truck, let alone a brand new hybrid car.
Or an old house. This house was built in 1898 and leaks like a sieve!
Welcome to the Usenet. Its your job to step over the steaming piles of
dung, looking for the gems of knowledge.
[email protected] wrote:
Remove the (political) restrictions on waste reprocessing. To keep the
high level product out of terrorist hands, put the gov't in charge of it
instead of the lowest bidder. This would probably be a contractor
facility located in the middle of a military base.
The end waste product would be a much lower volume than what we bury
today. That can be glassified and stored in a relatively small volume.
Don't find some desolate place in the middle of Nevada to bury it and
forget it. Build a 'temple' right in the middle of a major metropolitan
area. It'll be right there, where people can see it, remember why it was
build and keep alive the knowledge of why future generations must keep
the facility in good repair.
how does the power meter control your WH or other in-house loads?
It would have to have a device wired into the WH and other loads.
(some may just plug in.)
My local power company offers a thermostat that they can control to shut
off your AC during peak power demand periods.
There are *plenty* in Ohio too. Surprisingly, I never saw anyNo, Jim. Since all the Mexicans are leaving Mexcio, build them
across our southern border. Or use Sloman's back yard and an undersea
HV DC cable. Then it won't matter if it goes into meltdown. There
isn't one damn thing in that area worth saving, anyway.
