Thank you very much for the answers, well my goal it's just split the output, so it's just copies of the same signal, but, the problem is that I can't split the power and the signal without losing them, I need an "amplifier", but I don't know how to find it. Thanks
Well, this is where things might get tricky.
Let's simplify and say you want to split device A to provide a signal to device X and Y.
If both device X and Y provide 18V, then connecting their power wires together may end up causing problems.
Additionally, if A is the only device providing power, then splitting it's power output too many times could cause it to 'overload'.
In both cases, the ideal solution would be to *avoid* splitting the power wires, and simply provide 18V independently to the additional devices who *need* it.
As far as signal is concerned... if it's a one-way signal you *should* be able to split it.
If the receiving device sends back acknowledgements or requests then you will not be able to simply split this line.
Keep in mind that multiple splits on this will cause problems as well... as every split will weaken the signal.
At this point, there is too little I know about the device(s) and the only solution appears to be testing a couple of simple splits. Any more and you will need to know what kind of signal is on the wire to see if you can build or buy a repeater or buffer.
