bender
I am trying to design a Charge pump PLL with very high feedback and
reference dividers (around 2^15). The input clock is about 150 Mhz but
the output clock will be from 10-150 Mhz. If both N & M (dividers)
values are around 30,000, the Phase detector checks the edges every
220 uS, i.e. the output pulse width is in the order 200uS when the PLL
starts (Nanosim simulation).Since the output of the Charge pump + LPF
depends on the width of the output at Phase detector, the Vcontrol
(LPF output), varies very high at every edge that the VCO fails to
lock.
So far, I’ve been only considering altering a standard CP PLL
(designed to work with no dividers) to work for this. Should I be
considering other options such as fraction N PLL or maybe different
PLL type? Can a CP PLL work with high values at both the dividers
Note: . I haven’t been able to find any information on desiging very
high divider value PLL from books or internet searches.
The closest PLL I have come across that uses very high divider values
are for cellular transceivers which uses 30,000 at feedback clock
divider but no reference clock divider.
lock.
