Jamie said:
I am using a cyclone 2 FPGA, and have a propagation delay warning in one
of the megafunction's, lpm_divide. If we use a slower clock to this
block it will work properly, but the system clock is 27MHz which is too
fast for the bit width's of the numerator and denominator even with
pipelining selected in lpm_divide. I haven't used the cyclone PLL
before, but its lowest output frequency is 10MHz which is still a bit
higher than I would like to run the lpm_divide at.
You can use the megawizard to change the PLL, I think it allows multiple
clock outputs (in Cyclone 3 more than 2, but I think it was at least 2 in
Cyclone 2, too).
How fast do you need to divide? Once I had a similar problem, but with
LPM_MULT, because I needed some large bitwidths, but only at low frequency,
so I implemented it serially myself like this, for signed multiplications:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all;
ENTITY Multiplier IS
PORT(
reset : IN STD_LOGIC;
Clock : IN STD_LOGIC;
Factor1In : IN STD_LOGIC_VECTOR (23 downto 0);
Factor2In : IN STD_LOGIC_VECTOR (15 downto 0);
ProductOut : OUT STD_LOGIC_VECTOR (23 downto 0);
StartMultiplication : IN STD_LOGIC;
Completed : OUT STD_LOGIC
END Multiplier;
ARCHITECTURE logic OF Multiplier IS
SIGNAL Factor1 : SIGNED (39 downto 0);
SIGNAL Factor2 : STD_LOGIC_VECTOR (15 downto 0);
SIGNAL Counter : integer range 0 to 16;
type StateType is (WAIT_FOR_START, ADD, COPY_OUTPUT);
SIGNAL Product : SIGNED(39 downto 0);
SIGNAL State : StateType := WAIT_FOR_START;
BEGIN
PROCESS (reset, Clock)
VARIABLE temp : STD_LOGIC_VECTOR(39 downto 0);
BEGIN
IF (reset = '1') THEN
State <= WAIT_FOR_START;
ELSIF (rising_edge(Clock)) THEN
Completed <= '0';
case State is
when WAIT_FOR_START =>
if StartMultiplication = '1' then
if Factor1In(23) = '1' then
temp := '1' & x"ffff" & Factor1In(22 downto 0);
else
temp := '0' & x"0000" & Factor1In(22 downto 0);
end if;
Factor1 <= SIGNED(temp);
Factor2 <= Factor2In;
Counter <= 15;
Product <= (others => '0');
State <= ADD;
end if;
when ADD =>
if Factor2(0) = '1' then
Product <= Product + Factor1;
end if;
Factor1 <= Factor1(39) & Factor1(37 downto 0) & '0';
Factor2 <= '0' & Factor2(15 downto 1);
if Counter = 0 then
State <= COPY_OUTPUT;
else
Counter <= Counter - 1;
end if;
when COPY_OUTPUT =>
temp := std_logic_vector(Product);
ProductOut <= temp(39) & temp(36 downto 14);
Completed <= '1';
end case;
END IF;
END PROCESS;
END ARCHITECTURE logic;
If you don't need to perform your division at high frequency, you can
implement it serially, too. The algorithm is very similar and I think you
can use my code as a base. Take a look at this description:
http://bgu.uniclass.co.il/cs07/uploader.php?file=division.pdf&id=18
There are faster algorithms, but you'll need more LEs for it.
I could add another
external crystal, but I was wondering if it is possible to generate a
logic clock inside the FPGA by using flipflops etc. I have been told
that this is a bad idea to clock this way due to logic glitches, but am
not sure why or if that is true?
Yes, generating clocks with logic is a bad idea, because usually they are
not routed on the global clock nets inside the FPGA, so logic triggered
from this clock on opposite sides of the chip could be out of synch.
