Please Identify
Dear All
My first posting here.
I desperately need help in identifying these components. I think they are Selenium Rectifiers. The bottom one I pulled apart and it is filled with two lots of discs separated by a helical spring in the middle between them. The end caps are temporarily held in by hot melt glue. I will glue the caps in permanently with epoxy resin adhesive.
If they are Selenium Rectifiers, what can I use to replace them.
Thanks for helping out
Don
Test with a meter- a capacitor will show up as an open circuit, a rectifier (if working) will only conduct one way. If they are selenium rectifiers (I have only ever seen them in "stacks" with a screw through the middle), Then a normal silicon diode of the correct rating can be used.
