Hey guys, I am really new to this type of stuff, so as I go through this please point me to any materials that I need to read up on. I am so lost.
Well, here we go. I'm trying to create a controls system for a rocket. I know, big task. But basically all I have to do is set up a TinyCircuit to pull the pin on two solenoid at 750 feet up in the air (which I have successfully simulated by getting a buzzer to beep after traveling 10 feet up my stairs). This will deploy the two parachutes and hopefully turn the rocket around where it will then be controlled by two motors attached to the respective shroud lines in order to control the decent.
That is the general idea, but my electronics experience sucks and I need your guys' help. :/
I'm sure I can get the Arduino code working, but the actual circuitry is what gets me...
My biggest concern is if I can use the one battery (either a 9V or a 3-cell Lithium Polymer 250mAh 11.1 V battery) to power both the motors and the solenoids? Will this transistor set up work? How do I control the solenoid?
Sorry for my inexperience. I appreciate any help.
I also attached my attempt at a circuit diagram, as abysmal as it is. Note: the pin board would be attached on top of the DualMotor board.
