PLCC to PLCC thru-hole dip socket
Aldorus
I have a bunch of 84pin altera parts. I am going to be doing the
layout for a board this weekend and I would like to know the
layout of the PLCC thru-hole dip socket.
Its arranged as follows:
13 pins
11 pins
13 11 11 13
p p p p
i i i i
n n n n
s s s s
11 pins
13 pins
Wheresas the PLCC socket is just
21 pins
21 21
p p
i i
n n
s s
21 pins
I started to buzz out the connections but I wondered if there
was a layout/label somewhere I can point to, to see the
plcc pin # to plcc -thru-hole-dip-socket pin #
Spehro Pefhany
13 pins
11 pins
13 11 11 13
p p p p
i i i i
n n n n
s s s s
11 pins
13 pins
21 pins
21 21
p p
i i
n n
s s
21 pins
Look at the data sheet for the socket for the pin number layout. If
it's not there, look at another mfr's data sheet. Or just use the
footprint in your EDA package library.
John Devereux
13 pins
11 pins
13 11 11 13
p p p p
i i i i
n n n n
s s s s
11 pins
13 pins
21 pins
21 21
p p
i i
n n
s s
21 pins
Buzz it out and check it twice. You will have a bad day if you get it
wrong.
How do I know this, do I hear you ask???... :(
Aldorus
no datasheet - parts were bought on ebay.
I cant seem to find any good datasheets online ... but i am going to
go check mouser or jameco
If it's not there, look at another mfr's data sheet. Or just use the
EDA is gEDA. No extended library just the socket footprint
E
Eeyore
The manufacturer of the socket will have this info.
Graham
