Bob in Phx
Hello to all and thanks for looking.
I've been working on a used (but new to me) pioneer sx-727 receiver. When it
got to my house, the left channel was out, but a couple of shots of solder
to the numerous wirewrap connections fixed that...
The 2 phono inputs, the aux and the Mic inputs all work fine, all three of
the speaker outputs work fine, all the buttons and knobs are working and
static free. Even the FM works great. What doesn't work is the AM. The unit
has an external Ferrite rod (adjustable coil inside of it) and external AM
and ground antenna connections. But, the AM is flat dead.
So I attached my trusty Eico 324 AM RF genny to the antenna in, (with a cap
in-between), set the genny and the tuner to about 900 and swept the dial, no
400hz tone. Up or down the dial, no joy.
A quick check of the Internet and I found the full service manual here
http://www.hifi-museum.com/lib/misc/pioneer-sx-727_sm.pdf
The AM alignment section states to put a 455hz signal on pin 15 of the AM/FM
unit and tune to the upper end of the dial. I did that and got tone!!!!(see
page 13 of the manual above) so I believe that the oscillator is working
(right?????)
Took the Eico off pin 15 and put it on the antenna input and again no signal
is received. Note that when I first tried this connection, the rf genny was
set for almost no signal and then I ramped it up, in hopes that it would
make some noise, So I am fairly sure that "I" didn't blow the front end.
That is not to say that it wasn't already blown, or that I am dead wrong...
My request is that would someone be so kind as to look at the AM front end
and the AM/FM unit schematic and give me some advice as to where to start
checking. I am a self taught electronics hobbiest, who at very least knows
the hot end of the soldering iron(15 to 40 watts for circuit boards, 100
watts for the bigger stuff etc) .....
I have most of the Eico test equipement that was made in the 1950's (ie 324
signal genny, 145 signal tracer, 950b cap tester, 377 af generator, 245
vtvm, a couple of cap and resistor sub boxes and a 460 Oscope (with a
Leader 100mhz as a backup). I also have a Fluke 1805 frequency counter. This
is not to say that I fully know how to use them all (that damned 950b has be
stumped!!!), but I do take direction well!!!
So, if someone has the time to look at the schematic and can suggest what I
should do next, or what to look at, or how to test, that would be great. If
you can, please make the suggestions as detailed as you can, having never
worked in this field as a professional, nor having had any training, its
sometimes hard for me to understand the suggestions....
thanks in advance
bob in phx.
(right?????)
thanks in advance
bob in phx.
