Pioneer SD-P5565 Screen Very Red. Convergence problem?
TH421
I have a large screen Pioneer SD-P5565 projection television. It has a
convergence feature in which you line up the 3 colored crosshairs in
order to make the television view properly. However, the red crosshair
appears to be "bent" and thus causing the entire screen to turn very
red. What part do I need to repair this, and how would I go about
obtaining the part?
Thanks :-D, TH421
Art
Probably need to change the convergence output device and check for poor
conections as well as defective components on the convergence output board.
Look for poor solder connections, overheated components and failing
capacitors.
Shoreline Electronics
Even after changing the defective part , this model will require advanced
convergence alignments which you will not want to mess with.
Find a servicer that is experienced on your brand set.
Jeff Stielau
Shoreline Electronics Repair
344 East Main Street
Clinton,CT 06413
860-399-1861
860-664-3535 (fax)
[email protected]
"If you push something hard enough it will fall over."
Fudd's First Law of Opposition - Sir Sidney Fudd
H
H. R. Bob Hofmann
obtaining the part?
Thanks :-D, TH421
If the red grid patern is bent compared to the blue and green, that is
one problem called convergence.
The entire screen looking red is a separate issue, due to the red gun
being turned on more than the blue and green guns. Is the red
appearance present on an actual picture, or only when you are in the
setup/convergence mode?
H. R. (Bob) Hofmann
