Hi All,
Been a while ...
I've been working on a Pioneer SC-1227 A/V Receiver with the initial problem being, the sound started to intermittently drop out for a short time then come back. When I tested it for several hrs it seemed fine then boop ... sound cuts out for a short time then comes back and is good for a while then goes again. The owner also said a few times it made a loud pop noise in the speakers followed by a very loud screeching sound. After this occurred a couple times he disconned it as he was afraid for his nice speakers ... good move. And I believe this started after the intermittent sound issue started. First step for me was to look at the diag mode to see what faults if any were recorded.
There were 3 O/L occurances and I think 1 over temp. I did a hard factory reset and ran it again but intermittent sound issue persisted ... curious I was never able to get it to pop and scream. Possibly because I couldn't turn it up very loud maybe ? I live and work in my condo, can't make a lot of noise.
So my first inclination was to replace ALL the Mosfets on the amp ... now here's where it gets weird ... $50 later ...
After doing this now the unit will not stay powered up ... starts up ... stays one for about 3 secs then protection shuts it down. I took it all apart again and kicking my self for not going diag mode to get errors again ... DOH! I checked and rechecked for mistakes or problems with the new FETS and found nothing.
I'm willing to bet that the O/L protection is kicking in again ... only thing is when it was working but had the sound cutting in and out the 3 O/L trips never shut the unit off ... wth?
I've been scouring the net looking for explanations of what failure or error conditions typically trip the O/L protection circuit and found very little helpful info.
Anyone here familiar with O/L causes ?
Can anyone hazard a guess as to why a set of new FETS would cause the unit to fail even worse by not staying on ?
The O/L circuit in the service manual looks pretty simple but I can't really figure it out.
One thing I did not due because 1) I was lazy and 2) The DC detect had zero counts was to actually check the PS voltages around the unit. This design made it difficult to do so ... so maybe hence my hesitation to measure PS voltages but I can probably safely assume PS voltages are good since no DC detect errors were recorded.
Also I can assume the PS was all good since it ran before I changed the FETS.
All the PS filter caps look good ... no signs of leaking or swelling but that's no gaurantee ... it is a pretty old unit but worth fixing.
Another idea I had was that one of the FET driver chips may be malfunctioning ? Could that cause O/L condition ? As far as I can tell the O/L condition is caused by a voltage (high) on the speaker outputs ? But with these class D amps that may not be the case ... the Utube vid I saw on protection was for a Yammy that was not class D as far as I could tell and it had 4 redundant backups for voltage detection on the speaks OP.
My next step is to reassemble and see if I can get into the Diag mode and see whats going on now.
But any ideas out there will be welcome ...
Journey
PS>>> Here's a section of the schematic where OL circuit is located and a pic of the amp brd.
Been a while ...
Journey
