Comments inserted.
James Sweet said:
it
Oh joy, if I'd known how much hassle this would be I wouldn't have ordered
parts, oh well. Now that I'm into it I may as well see if I can finish. So
let me get this straight, the "protection" circuit *intentionally* blows the
output transistors?! What the hell were they thinking??
Yeah - their engineers should have gone to jail for this one. The
"protection" circuit monitors the output of a voltage divider, the output of
which is zero under normal circumstances. If the trigger line goes over
about 100 mV, a destructive bias voltage is applied. Just to save the cost
of a relay. In their all-in-one units, like the RX-570 and RX 590, etc, even
a bad cassette motor can blow the outputs.
Where are the 220 ohm resistors? I was looking casually for the usual
largish resistors but I didn't see them.
They are surface-mount types near each output transistor. You can measure
across the E-B connection after the shorted transistors are removed. One or
two will probably be good, a couple probably bad. If the resistor is bad
when the amp's power is applied, the amp will blow again.
The transistors involved in defeating the blow line are Q7401 and Q7406.
They are surface-mount types, and they are pretty hard to find, but once you
do, you can solder across the E-B junction of each one to defeat the BLOW
function. After the amp is repaired you must remove the short and restore
normal operation of this circuit. Otherwise someone could come along later
and sue your ass if the thing burns their house down, which is quite
conceivable on one of these if they fail and there's no "protection".
Pioneer says NOT to use a variac, use a 100W light bulb across the main fuse
instead. If the lamp glows bright for more than a split-second, cut power
immediately.
The way it should work if the amp is OK - the lamp glows for an instant as
the main power supply caps charge, then goes out, then may glow dimly
beginning a few seconds after that. I believe the blow line is monitored at
pin 6 of the connector at the end of the longer board. Should read less than
100 mV with respect to ground. In a borderline situation, say 90 mV, a 15K
resistor may be added from BLOW to ground to reduce the level a bit without
defeating the circuit.
What's the general procedure for
This usually isn't necessary if the amp is OK, but there is NO emitter
resistors to measure across, so you theoretically would have to break open a
B+ line to monitor current. I haven't done this, just looked at the schem
and eventually decided which pads to solder together to reduce bias and make
it run cooler. As I said, this isn't usually necessary if the other stuff is
OK.
Mark Z.
