Hey there, everyone! Long time no see! I've been busy trying to get into the US Air Force as an officer. We'll see how that goes...
Anywhoo, a friend of mine has a pinball table (Black Knight 2000, by Williams, for those interested.) I don't know if any of you are familiar with pinball flipper circuits. This is the first time I've worked on one. (Schematic attached). Each flipper has two coils. One is a 'power' coil, the other is a 'hold' coil. The power coil is designed to actuate the flipper quick and hard. After the flipper has traveled all the way out, it toggles a switch to disengage the power coil, and the holding coil should be enough to hold the flipper in place until the flipper button is released.
The upper-right flipper is actuated by a double-pole, double-throw switch (the end-of-swing (EOS) switch for the lower-right flipper.
Here's the problem I'm having: the lower-right flipper and the left flipper are both working perfectly. However, whenever the right flipper button is actuated, the upper-right flipper only flips, and then goes back down. This tells me that the power coil is getting power. What I don't understand is #1) how there can be power to the power coil, and yet not to the holding coil of the upper-right flipper, and #2) why the flipper powers only once, and then falls. By my understanding of the logic for the circuit, the flipper should kick back up every time the end-of-swing switch is deactivated?
I'm having trouble understanding the logic, and where any potential problems might be.
The power coil is getting power, so we know the circuit is complete at least to that point. Could the holding coil be bad? I measured the continuity (in-circuit), and it seemed to be good. I also measured against a known-good brand new coil, and seemed to come up with the same numbers.
I can switch out the coil with a known good one, but I'd hate to go through all that work and then find out it was something else. (Did that once already. The upper coil wasn't even working before, so I switched out the coils. Didn't work, so I changed them back. Then I found a broken wire at the EOS switch for the bottom-right flipper. That got me to this point.)
Any help on this is much appreciated.
