I'm a beginner in MCU programming and also very eager to learn lots about it. Recently I have acquired the "Aptinex development board rev.6" which has many features already attached. I also bought a PIC18F4550 to plug it in the board. I've managed to understand how the basics of I/O operations work, but now I have stumbled on the LCD, which is attached to the development board. I found the code bellow in one of many tutorials pages all over google, and decided to try it out because it seemed simple enough. The code works without problems.
The question that I have is, could someone kindly please explain what is going on in the function Lcd_port (char a);, located in the lcd.h file bellow. Can't understand what conditions are tested and how they are true or false.
As mentioned before, the code works perfectly fine. I just really need someone to explain how that part works. Any help will be highly appreciated!
Code:
//File name 'LCD_Display_String_Original.c'
#define _XTAL_FREQ 8000000
#define RS LATD0
#define EN LATD1
#define D4 LATD2
#define D5 LATD3
#define D6 LATD4
#define D7 LATD5
#include <xc.h>
#include "lcd.h"
void delay_ms(unsigned int delay_value)
while(delay_value-- > 0)
// While desired delay value is more than 0, decrement that value by 1 after each 10ms
__delay_ms(1);
// Wait 10ms
int main()
TRISD = 0b00000000;
Lcd_Init();
while(1)
Lcd_Clear();
Lcd_Set_Cursor(1,1);
Lcd_Write_String("Hello world!");
delay_ms(1000);
Code:
//File name 'lcd.h'
#include <xc.h>
#include <stdio.h>
void Lcd_Port(char a)
if(a & 1)
D4 = 1;
else
D4 = 0;
if(a & 2)
D5 = 1;
else
D5 = 0;
if(a & 4)
D6 = 1;
else
D6 = 0;
if(a & 8)
D7 = 1;
else
D7 = 0;
void Lcd_Cmd(char a)
RS = 0; // => RS = 0
Lcd_Port(a);
EN = 1; // => E = 1
__delay_ms(4);
EN = 0; // => E = 0
Lcd_Clear()
Lcd_Cmd(0);
Lcd_Cmd(1);
void Lcd_Set_Cursor(char a, char b)
char temp,z,y;
if(a == 1)
temp = 0x80 + b - 1;
z = temp>>4;
y = temp & 0x0F;
Lcd_Cmd(z);
Lcd_Cmd(y);
else if(a == 2)
temp = 0xC0 + b - 1;
z = temp>>4;
y = temp & 0x0F;
Lcd_Cmd(z);
Lcd_Cmd(y);
void Lcd_Init()
Lcd_Port(0x00);
__delay_ms(20);
Lcd_Cmd(0x03);
__delay_ms(5);
Lcd_Cmd(0x03);
__delay_ms(11);
Lcd_Cmd(0x03);
Lcd_Cmd(0x02);
Lcd_Cmd(0x02);
Lcd_Cmd(0x08);
Lcd_Cmd(0x00);
Lcd_Cmd(0x0C);
Lcd_Cmd(0x00);
Lcd_Cmd(0x06);
void Lcd_Write_Char(char a)
char temp,y;
temp = a&0x0F;
y = a&0xF0;
RS = 1; // => RS = 1
Lcd_Port(y>>4); //Data transfer
EN = 1;
__delay_us(40);
EN = 0;
Lcd_Port(temp);
EN = 1;
__delay_us(40);
EN = 0;
void Lcd_Write_String(char *a)
int i;
for(i=0;a[i]!='\0';i++)
Lcd_Write_Char(a[i]);
void Lcd_Shift_Right()
Lcd_Cmd(0x01);
Lcd_Cmd(0x0C);
void Lcd_Shift_Left()
Lcd_Cmd(0x01);
Lcd_Cmd(0x08);
