PIC18 - eeprom write
Randy Day
This is my first attempt to write to eeprom
using a pic18f2455. Obviously it isn't
working. ;)
Most of it is straight out of the datasheet;
can anyone point out what I'm missing? Thanks.
;write serial number to EEPROM
; EEADR initial value is 4
; MOVWF EEADR ; Lower bits of Data Memory Address to write
DECF EEADR ; decrement EEPROM address for ser# storage
MOVF NIBBLE_TEMP, W ; ser# value to store
MOVWF EEDATA ; Data Memory Value to write
BCF EECON1, EEPGD ; Point to DATA memory
BCF EECON1, CFGS ; Access EEPROM
BSF EECON1, WREN ; Enable writes
BCF INTCON, GIE ; Disable Interrupts
MOVLW 55h ; Required Sequence
MOVWF EECON2 ; Write 55h
MOVLW 0AAh ;
MOVWF EECON2 ; Write 0AAh
BSF EECON1, WR ; Set WR bit to begin write
; User code execution
BTFSC EECON1, WR
GOTO $-2
; test for write errors (WRERR) would go here...
BCF EECON1, WREN ; Disable writes on write complete (EEIF set)
BSF INTCON, GIE ; Enable Interrupts
Richard Seriani, Sr.
working. ;)
<snip>
Randy,
I am very new to PIC MCUs, but you might want to try the PIC list. Lots of
folks there who know this stuff.
http://www.piclist.com PIC/SX FAQ & list archive
Good luck,
Richard
Sambo
Randy said:
Richard Seriani, Sr. wrote:
[snip]
Lots of
Bookmarked. Thanks!
Just out of curiosity, what programmer are you using?
I have built the PIC-PG1 (JDM with 6.2V zener instead of 8.2V),
always had 90% failure rate with 16F626A now.
after over a year later can't program the new 18F2320s or the old 16f628s.
The new IC-PROG(G) I have noticed some strange things so I am loosing faith
in it too.
Just about ready to build a parallel programmer and control it from LINUX
if I could only find some detail info on programming algorithms, in case that
is available doesn't work.
Cheers, Sam.
Randy Day
faith in it too.
I'm using the PicKit 2 from MicroChip.
It came with a 16F690 as a learner chip,
but I'm using it now to program 18F2455's.
I've had no problems at all so far; it
works great. Then again , mine is a
hobbyist environment, not day-in-day-out
use. IIRC, it retails for about US$80.
It came with a USB programmer dongle,
a preassembled breadboard, MPLAB and the
PicKit programming software (Windows),
lots of tutorial help and code examples.
Not to mention lots of stuff on the CD
that I've never even looked at... :)
One thing I did have to do was download
a later version of the PicKit software
(v1.21) in order to program the newer
PIC18 series.
Anyone who wants to do in-circuit
programming with the PicKit 2 should read:
http://pic18fusb.online.fr/wiki/wikka.php?wakka=PicKit2Header
Sambo
PIC18 series.
Maybe I'll finally break down and buy one of those.
I would be nice to compile and burn.
Paul E. Schoen
working. ;)
MOVLW 0AAh ;
BTFSC EECON1, WR
GOTO $-2
BCF EECON1, WREN ; Disable writes on write complete (EEIF set) BSF
It is very helpful to have a debugger such as the ICD2, but it costs about
$150, so might be out of reach for a hobbyist. The software simulator is
extremely powerful, however, and you might be able to track down your
problem in that way.
You can try some of the following code. I am using a PIC18F242. I think it
works for EEPROM, but now I write to Program Flash Memory, which I think is
recommended as more reliable:
EEPROMread:
MOVLW DATA_EE_ADDR ;
MOVWF EEADR ; Data Memory Address to read
BCF EECON1, CFGS ; Access program FLASH or Data EEPROM memory
BSF EECON1, RD ; EEPROM Read
MOVF EEDATA, W ; W = EEDATA
RETURN
EEPROMwrite:
MOVLW DATA_EE_DATA ;
BCF INTCON, GIE ; Disable interrupts
MOVLW 55h ;
MOVLW 0AAh ;
MOVWF EECON2 ; Write AAh
BSF INTCON, GIE ; Enable interrupts
; user code execution
RETURN
;Read a block of data from CODE_ADDR into BUFF_ADDR length BUFF_LEN
FlashRead:
BSF EECON1, EEPGD ; Point to Program Flash memory
MOVFF CODE_ADDR_UPPER, TBLPTRU ; Load TBLPTR with the base
MOVFF CODE_ADDR_HIGH, TBLPTRH
MOVFF CODE_ADDR_LOW, TBLPTRL
MOVFF BUFFER_ADDR_HIGH, FSR0H ; point to flash buffer
MOVFF BUFFER_ADDR_LOW, FSR0L
MOVFF BUFFER_LEN, COUNTER ;Initialize byte counter
READ_BYTE
TBLRD*+ ; read into TABLAT and increment
MOVF TABLAT, W ; get data
MOVWF POSTINC0
DECFSZ COUNTER
BRA READ_BYTE
EndReadFlash
RETURN
;Write a block of data from BUFF_ADDR into CODE_ADDR length BUFF_LEN
FlashWrite:
MOVFF BUFFER_LEN, COUNTER_HI ; number of bytes to write
RRNCF COUNTER_HI,F
RRNCF COUNTER_HI,F
RRNCF COUNTER_HI,F ;Divide by 8
MOVF COUNTER_HI, W
ANDLW b'00011111' ;Mask off rotated bits
MOVWF COUNTER_HI
MOVFF BUFFER_ADDR_HIGH, FSR0H ; point to buffer
PROGRAM_LOOP
MOVLW 8 ; number of bytes in holding register
MOVWF COUNTER
WRITE_WORD_TO_HREGS
MOVF POSTINC0, W ; get low byte of buffer data
MOVWF TABLAT ; present data to table latch
TBLWT+* ; write data, perform a short write
; to internal TBLWT holding register.
DECFSZ COUNTER ; loop until buffers are full
BRA WRITE_WORD_TO_HREGS
PROGRAM_MEMORY
BSF EECON1,EEPGD ; point to FLASH program memory
BCF EECON1,CFGS ; access FLASH program memory
BSF EECON1,WREN ; enable write to memory
BCF INTCON,GIE ; disable interrupts
MOVLW 55h
MOVWF EECON2 ; write 55h
MOVLW 0AAh
MOVWF EECON2 ; write AAh
BSF EECON1,WR ; start program (CPU stall)
BSF INTCON,GIE ; re-enable interrupts
DECFSZ COUNTER_HI ; loop until done
BRA PROGRAM_LOOP
BCF EECON1,WREN ; disable write to memory
RETURN
ERASE_BLOCK
MOVFF CODE_ADDR_UPPER, TBLPTRU ; load TBLPTR with base address of memory
block
BSF EECON1,FREE ; enable Row Erase operation
MOVLW 55h
MOVLW 0AAh
BSF EECON1,WR ; start erase (CPU stall)
TBLRD*- ; dummy read decrement
return
