PIC10F200, MPASM: Pin input, then output
Hello,
I am writing MPASM code which should make GPIO,1 of PIC10F200 an output low for 10ms, then an input for 790ms.
This is repeated over and over.
However, the GPIO,1 pin does not become an input when it should......it actually stays as an output low.
-I know this because there is a 47K pull-up resistor on this pin, and it does not pull the pin up.
Do you know what i am doing wrong?
(Is it something to do with the ReadModifyWrite?)
....Do i have to just do a few dummy read instructions (eg, btfsc GPIO,1 nop nop ) after setting it to an input to make it really become an input?
By the way, here is the code....
Code:
;vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
    list      p=10F200            ; list directive to define processor
    #include <p10F200.inc>        ; processor specific variable definitions
    __CONFIG   _MCLRE_OFF & _CP_OFF & _WDT_OFF
#define		PIN_TRIGGER		0
#define		PIN_SYNC		1
#define		PIN_PHASE		2
#define		PIN_FPM			3
;VARIABLE DEFINITIONS
sync_phase_FLAG      	EQU 	0x13    	;insync of bit 0 is clear
FPM_FLAG				EQU		0x14		;FPM=75 if bit 0 is clear
ACDC_FLAG				EQU		0x15		;AC if  its bit one is set
counter             	EQU 	0x15    	;counter for delays
counter1            	EQU 	0x17
counter2            	EQU 	0x18
counter3            	EQU 	0x19
counter4            	EQU 	0x1A
count					EQU		0x1B
phase_REG1				EQU		0x1C
phase_REG2				EQU		0x1D
    ORG     0xFF            ; processor reset vector
; Internal RC calibration value is placed at location 0xFF by Microchip
; as a movlw k, where the k is a literal value.
        ORG     0x000           ; coding begins here
        movwf   OSCCAL          ; update register with zero
;vvvvvvvvvvvvvvvvvvv          OPTION REGISTER            vvvvvvvvvvvvvvvvvvvvvv
start
    	movlw       0b11000111
    	option                                  ;set option register
;SET PORTS UP AS INPUTS/OUTPUTS.
        movlw   0b00001110      ;Set ports to input or output
        tris    GPIO
		nop
;Initiate the ports
		bcf		GPIO,PIN_TRIGGER			;Ensure trigger output low
;start up delays
	call	delay_195ms
	call	delay_195ms
	call	delay_195ms
	call	delay_195ms
;Check for ACDC input
;VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
;0000000000000000000000000000000000000000000000000000000000000000000000000
FPM60_INSYNC
;Send trigger
		bsf		GPIO,PIN_TRIGGER
		call	delay_10us
;Set sync pin to an output
        movlw   0b00001100
        tris    GPIO
		nop
;Send sync pulse
		bcf		GPIO,PIN_SYNC
		call	delay_10ms
;Set sync pin to an input
       	movlw   0b00001110
        tris    GPIO
		nop
		call	delay_195ms
		call	delay_195ms
		call	delay_195ms
		call	delay_195ms
		call	delay_30ms
		goto	FPM60_INSYNC
delay_10us
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	retlw	0x00
delay_2ms
;	clrwdt
    movlw   0x04			;4
    movwf   counter1
kkk
    movlw   0xA7			;167
    movwf   counter
jjj
    decfsz  counter,1       ;INNER LOOP=501us
    goto    jjj
    decfsz  counter1,1
    goto    kkk
    retlw   0x00
delay_5ms
;	clrwdt
    movlw   0x0A			;10
    movwf   counter1
mmm
    movlw   0xA7			;167
    movwf   counter
nnn
    goto    nnn
    decfsz  counter1,1
    goto    mmm
    retlw   0x00
delay_10ms
;	clrwdt
    movlw   0x14			;20
    movwf   counter1
qqq
	clrwdt
    movlw   0xA7			;167
    movwf   counter
ppp
    goto    ppp
    decfsz  counter1,1
    goto    qqq
    retlw   0x00
delay_30ms
    movlw   0x3C			;60
    movwf   counter1
sss
;	clrwdt
    movlw   0xA7			;167
    movwf   counter
rrr
    decfsz  counter,1       ;INNER LOOP = 501us
    goto    rrr
    decfsz  counter1,1
    goto    sss
    retlw   0x00
delay_50ms
    movlw   0x64			;100
    movwf   counter1
ttt
;	clrwdt
    movlw   0xA7			;167
    movwf   counter
vvv
    goto    vvv
    decfsz  counter1,1
    goto    ttt
    retlw   0x00
delay_195ms
    movlw   0xFF			;100
    movwf   counter1
XXX
;	clrwdt
    movlw   0xFF			;167
    movwf   counter
YYY
    goto    YYY
    decfsz  counter1,1
    goto    XXX
    retlw   0x00
    END
on a couple variations of the chip the GP0 is multiplexed with the comparator. Try disabling the comparator by loading '00000000' into the CMCON0 register right after you configure your option register and before your main program starts.
